Topic: Upgrading from Denon mc4000 dj controller
mysticaPRO InfinityMember since 2008
Hi guys,
I've been djing using denon mc4000 for a while now, never had any issues with it, sound quality pretty good.. but now I'm looking to upgrade a bit to something with much better sound. And I'll still like to get something around the same size or a lil bit bigger. Any recommendations will be appreciated
geposted Sat 16 Apr 22 @ 7:42 am
wow, no recommendation ?
geposted Wed 20 Apr 22 @ 9:52 am
Im sure the Denon sound is fine, and "much better sound" probably related to your speakers if missing anything .. :)
Upgrade to a "better" controller.. Perhaps Denon Prime 2 (or 4)
Or Pioneer DDJ-1000
But so many others that can be recommended as well. Depends on your needs and preferences
Can look here for some inspiration:
https://virtualdj.com/products/hardware.html
geposted Wed 20 Apr 22 @ 11:31 am
Thank u for your recommendations.
Think I might be going for a Roland dj 505 or pioneer ddj sr2.
Anyone use both, which do you prefer pls?
geposted Wed 04 May 22 @ 5:38 pm
I use Roland and the sound is excellent
geposted Thu 05 May 22 @ 8:37 pm
I also use the Roland dj-505 and apart from the different way effects are handled from Serato where you can switch the assignment of the effects between decks, the virtual DJ implementation works great. It also supports split pad pages.
geposted Sat 07 May 22 @ 8:06 am
Thanks guys, I'm getting the roland dj 505. And even cooler the controller comes with a bag :)
But If you guys use any other carry bag, pls recommend. Thanks
geposted Sat 07 May 22 @ 9:31 am
