Hello,
I brought up this potic by a user of the French forum,
here is what it says below
I revive this subject on the effect (backspin) which has a big BUG, even with the new update of virtual dj. I tried with 3 different computers and still the same problem. Please forward the info.
The problem is when you want to use the backspin at the bottom of the settings, its beug on titles with 44 or 48 Hz sampling. I even used different manipulations on the sampling in the video, the problem is either the backspin effect which is not supported by the button (SLIP) or VDJ has screwed up somewhere. In any case tried to contact the developers to see if they know about it.
I put a video on Youtube to better explain the beug. Here is the link :
geposted Sat 16 Apr 22 @ 8:42 am
