Topic: M3U Xtractor
Quite often I find that I'm wanting to export full tracks based on playlists (from the history folder or otherwise curated) in VDJ to load onto my phone or USB drive to be used on the go (e.g. on road trips, etc.) . The issue I find is that "Copy To..." adds an unwanted search path to the VDJ database and doubles up the track listings thereafter, requiring me to having to remove said new path. Additionally, I have to create a playlist with the new relative paths to have the tracks played in the needed order.
So I have written a quick application to extract the tracks, and create a new playlist if needed, based on playlists that have already been created in VDJ. I'm happy to share, if you think it will be useful to you - just let me know and I'll package it up.
Screenshot:
geposted Fri 22 Apr 22 @ 2:45 am
