Hello! I saw the Launchpad X is supported, will the Launchpad Pro Mk3 be supported anytime soon? Debating whether or not I should return my pro and get the X since I really would love to use my launchpad with Virtual DJ. Thanks!
geposted Fri 22 Apr 22 @ 3:47 am
Not a plan for the near future i am afraid.
We could work together remotely and provide you some basic mapping, but it will take some time and efforts from both sides, so if you need some fast and easy results, better return and get one of the currently supported ones
geposted Sat 23 Apr 22 @ 3:00 pm
