Team does any have troubles with the memory saturation due the upgrade of Virtual DJ, this issue is making my laptop freeze due this saturation of memory, in some momento the peak is above 60%.
geposted Sat 23 Apr 22 @ 2:52 am
How much memory does your computer have?
If it is very little, then you can try set the mathEngine setting to disabled, as the stems do use a bit of memory.
geposted Sat 23 Apr 22 @ 5:34 am
