Is that true? give them at least 30 minutes of demo
geposted Mon 25 Apr 22 @ 4:59 am
You can try DVS for 10 minutes without a license
geposted Mon 25 Apr 22 @ 7:20 am
DVS section doesn't even show up in the settings
geposted Mon 25 Apr 22 @ 7:40 am
It will show up when you add a timecode input to your audio config
geposted Mon 25 Apr 22 @ 9:33 am
I go into the "audio", press input "time code signal' - no tab appears
geposted Mon 25 Apr 22 @ 1:45 pm
Which sound card are you using in your Audio Setup ?
The TIMECODE button in Audio setup will automatically set Timecode inputs for you, if it's a known sound card (supported controller) and has the inputs pre-defined.
if not set automatically, you can still set it up manually.
geposted Mon 25 Apr 22 @ 1:49 pm
