Is there a way to export history or any playlist back out to Tidal?
I'm able to do this in DJayPro and use it to share some playlists I build in VDJ with other folks.
geposted Mon 25 Apr 22 @ 7:39 pm
Sure, just create a new tidal playlist and drag&drop the songs you want on it.
geposted Mon 25 Apr 22 @ 7:54 pm
I can see that this does create the playlist inside Tidal but I can't seem to get any tracks in there. Sometimes they do show up, but then on refreshing the playlist it'll give me an "Error downloading playlist":
https://imgur.com/a/Kjvw1hk
Did you do anything special for yours to work?
geposted Mon 25 Apr 22 @ 10:14 pm
