Hey guys, i'm thinking about using VDJ to run a hobby radio station and i understand how to make, load and adjust playlists but my question is if i have say 4 playlists that last 6 hours each (named 80s, 90s, 00s and 10s) can i somehow load the 4 individual playlists into automix so it will play 6 hours of 80s, then automatically start to play to 90s playlist and then the 00.?.
Any advice would be a great help - thank you x
geposted Fri 29 Apr 22 @ 4:28 pm
You could use the event scheduler to load the various playlists at different times
https://www.virtualdj.com/manuals/virtualdj/interface/topsection/appcontrols/eventscheduler.html
geposted Fri 29 Apr 22 @ 4:37 pm
I must confess i've never used the event scheduler but i'll have a look at some tutorials - thanks for the tip my friend x
geposted Fri 29 Apr 22 @ 4:57 pm
Can it also be used to play samples ie station ids and drop ins at specific times?
geposted Fri 29 Apr 22 @ 4:58 pm
Yes
geposted Fri 29 Apr 22 @ 5:06 pm
Just played about with it - cheers guys x
geposted Fri 29 Apr 22 @ 5:17 pm
