good evening,
can you tell me if this is bug or not
if I mark a cue point 1 and I do not make a cue point 2 and
I directly make a cue point 3, and my marker is on cue 3 and I press the adjust_cbg or adjust_cbg +4 button
cue 3 goes to cue 2, ie it deletes cue3 and creates cue2.
thank you
thank you
geposted Wed 04 May 22 @ 9:17 pm
I don't exactly understand what you are saying, I think I have an idea of your explanation, but it sounds to me that you have autoSortCues enable (Yes option) on you VDJ Settings.
Change autoSortCues to NO and re test.
Hope it works.
Hope it works.
geposted Thu 05 May 22 @ 1:41 pm
no it's not from that
In testing on build 6800 this problem does not exist.
with build 6921 this problem exists.
geposted Thu 05 May 22 @ 5:12 pm
I can reproduce that behavior.
It is as if, making a cbg adjustment (using either the controller, or the skin),(adjust_cbg), as LIMOL has found, immediately causes an autoSortCues type of action, on all existing cues on the loaded track.
Test preformed..
0) autoSortCues set to NO in settings
1) Set hotcues with, hotcue8 at first beat.. and continued till hotcue1 was set near end of track.
2) Clicked the "Adjust CBG" arrow on the skin, once. (CBG adjust arrows, appear after clicking the BPM in the Deck Info area, and which appear below the Edit and Tap buttons)
3) All hotcues are immediately reordered with ... hotcue1 at first beat and hotcue8 near the end of track.
producing the same/similar behavior that occurs if the setting autoSortCues is set to YES
Note:
unlike setting autoSortCues is set to YES, which affects all tracks, this only auto-sorts the hotcues on the, one, loaded track.
Note 2:
and could be an awesome new feature, a per track auto-sort of hotcues, if it can be tweaked to not happen when attempting to adjust the beat grid.
ver 6921
Win 10
Test preformed..
Note:
Note 2:
ver 6921
Win 10
geposted Thu 05 May 22 @ 6:47 pm
I thought I posted, bug confirmed here
set_cue 4 & goto +1 & set_cue 2 & goto +1 & set_cue 1 & goto -3 & wait 2000ms & adjust_cbg +0
geposted Thu 05 May 22 @ 6:55 pm
Will be fixed in next update
geposted Sat 07 May 22 @ 8:01 am
