Topic: Could any1 share their laptop hardware setup?
ch3lm4nHome userMember since 2012
I'm planning to start a setup my a Surface notebook but I don't know how to connect voice microphones to the notebook. It's running voice mikes separate better?
geposted Mon 09 May 22 @ 5:04 pm
You normally don't connect your microphone direct to your laptop. It's usual to have a mixer/controller connected to the laptop. Controllers usually have a microphone channel that you connect to. Some DJs have an extra small mixer added for the microphone, it depends on the quality of the mixer/controller.
My System Specs;
MacBook Pro 15” 2017 (Touch Bar), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Monterey 12.3.1, 500gb SSD Bootcamped with Windows 10 x64bit. External WD Passport Ultra 2Tb HD containing Music & Video databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2021 b6921 and Controllers - Denon MC7000, Denon MC6000 MkII.
geposted Tue 10 May 22 @ 8:48 am
