It looks like my thread was deleted so I will repost as no solution has been found.
Deck "A" mutes itself, never had this problem with the DJM900 NSX. I will include pictures of the different settings I have used. Unless all channels are set to "USB" one of the decks mutes.
geposted Wed 11 May 22 @ 2:31 am
Can you show pictures of the controller mapping and audio setup as well?
geposted Wed 11 May 22 @ 6:01 am
Is that what you are referring to?
geposted Wed 11 May 22 @ 9:19 am
VDJ does not have a mixer order with deck 1&2 on the right, so easiest would be to switch it around and use deck 1&2 on the left side of the mixer and use channels 3&4 for line in
If you do want to keep this, you could use decks 3 & 4 in vdj, and use mixerorder 1234
geposted Wed 11 May 22 @ 9:37 am
i will try tis setup tomorrow, thank you
geposted Wed 11 May 22 @ 10:26 am
The same problem still happens, the mixer is requiring that each deck has two channels allocated to it or it mutes one of the decks. I rearranged the set up as follows in the picture.
Lets say deck A is sent to channel 3, the physical controls of the mixer on channel 2 are controlling the virtual DJ deck (even though the deck is told to be on channel 3). Same happens if I send Deck A to channel 1, physical controls from other channel (low, mid, high, ) will still control the virtual deck even though nothing is assigned to it.
geposted Thu 12 May 22 @ 2:06 am
As Adion wrote, you need to use Decks 3 and 4 in VirtualDJ. So, if you use the default 2 Decks skin of VDJ (not sure if the old one supports this), map a button as ..
deck 3 leftdeck & deck 4 rightdeck
then press it to make Decks 3 and 4 as Left and Right and get them on the skin.
After that you need to correctly route the sound of Decks 3 and Decks 4 to the USB channels 5,6 and 7,8 of the NXS
So to summarize...
- Use the Default Pro Layout 2 Decks skin (not the old/legacy one - at least for testing)
- Set Mixer Order to 1234 (from Settings)
- Use the default Audio setup (deck1->1,2, deck 2->3,4, deck3->5,6 , deck4->7,8)
- Press the button you mapped as above , to make Decks 3 and 4 as Left/Right
So to summarize...
geposted Thu 12 May 22 @ 10:02 am
So to summarize...
So to summarize...
I will try this tomorrow, not sure why in this setting any deck would be getting input from two channels. This is also the identical set up I was using with virtual and the DJM900NSX, but tomorrow I will try with the setting you recommend.
geposted Thu 12 May 22 @ 11:03 am
So to summarize...
So to summarize...
I set up all four decks and assigned each deck to a channel, 1 - 4 with virtual DJ via USB with all four channel settings set to USB.
1 of the 4 decks is still muted.
geposted Fri 13 May 22 @ 2:54 am
Does anyone know why one of the four decks would still be muted in this setting? I think the issue is with the physical mixer itself.
geposted Sat 14 May 22 @ 3:09 am
