I recorded a lot of songs in automix for a very long track, it's about 15 hours long, as I drive a lot in my truck. Does VDJ have a feature where I can put in "time stamps" so if I hit the "next track" button on my music player, it will jump say, 5 or 10 mins forward of my recording? Thanks.
geposted Sat 14 May 22 @ 8:47 pm
good evening, the best is to assign a key or a button to the action
mix_and_load_next
this action switches to the other track in the automix window
mix_and_load_next
geposted Sun 15 May 22 @ 1:11 am
You can use hotcues.
Create a new hotcue at the start of each song.
Then use the actions goto_cue +1 and goto_cue -1 to jump between the tracks.
geposted Fri 20 May 22 @ 9:00 am
I believe OP is meaning like .cue files as to skip thru the recording when playing on some other device. I think .cue is only CDA.
*edit* [retracted split comment]
geposted Fri 20 May 22 @ 9:04 am
In that case you can enable the option for VirtualDJ to also write a .cue file during recording.
It works like a charm.
recordWriteCueFile
recordWriteCueFile
geposted Fri 20 May 22 @ 9:08 am
recordAutoSplit will split the recording to several files. Which defeats the purpose of adding a list of files in automix and making a recording out of them.. :P
.cue files are not exclusive to CD Audio. But not all apps and/or devices support them.
However it worths a try.. On modern media players / infotainment systems that run android, or provide Android Auto / Apple Car Play functionality it's easy to find a media player that supports .cue files
geposted Fri 20 May 22 @ 9:14 am
Thanks everyone. I'll try next time I'm home.
geposted Wed 25 May 22 @ 4:09 am
