Topic: Script/code for toggling on/off applying effects on stems
SepatroPRO InfinityMember since 2019
Hello, i often use effects applied on stems - but not always. Is there an easy way toggle the effects on/off on a stem, i.e. the equivalent of clicking the little icons as indicated in the image?
Side question: is it possible to have some effects applied to stems, and others not?
geposted Tue 17 May 22 @ 7:17 am
check the verb definition for
effect_stems
geposted Tue 17 May 22 @ 7:55 am
You need to use effect_stems action
effect_stems vocals
And no, it's not possible to have some effects working one way and some the other
geposted Tue 17 May 22 @ 7:56 am
