Can you add your own custom logo well using virtual dj
geposted Mon 23 May 22 @ 10:45 pm
Yes you can.
Also, little known fact, you can also use video clips instead of a static image.
And if you are in a position to create your own video logo, you can also add transparency to it.
Just an example: https://youtu.be/kUySRGHY75M
The logo on this video (top right corner) is a transparent video file playing in a loop
geposted Wed 25 May 22 @ 8:08 am
