Hello everyone.
I would like to know if it's possible to change the localisation of the sampler dowland from the extension lab of virtual dj. When i try to dowland some (effects, samples...), there going to the folder "onedrive" which i don't have anymore and i can't find them in the sampler of the application.
Thank you for your help.
geposted Wed 25 May 22 @ 1:21 pm
Log out from OneDrive in windows, and it should restore your Documents location.
Alternatively, you can manually fix your Documents location as well:
https://www.cedarville.edu/insights/computer-help/post/how-to-set-default-document-folder-location-in-windows
geposted Wed 25 May 22 @ 2:00 pm
thanks for your answer. It doesn't work with or without onedrive... and i try to change the localisation directly in windows but the change is impossible because of file but i don't know which one.
So do you know if it's possible to change the localisation directly in virtual dj ?
geposted Wed 25 May 22 @ 5:34 pm
