Good day. How to display the next item in VDJScript when displaying a slideshow? Thank you for your help.
geposted Wed 25 May 22 @ 1:33 pm
There isn't a script.
you could turn time down, you could use multiple folders which can be switched with the effect string.
geposted Wed 25 May 22 @ 2:00 pm
Indeed missing currently, but I will see if it can be added in a future update
Thank you....
geposted Wed 25 May 22 @ 5:13 pm
Hi, thanks for
-Slideshow plugin has Next and Previous buttons
If video and image files are included, Next and Previous will skip only the image files. Video files will not be skipped.
geposted Wed 01 Jun 22 @ 8:40 pm
In version 7021, I no longer noticed any problem with the previous next buttons.
geposted Tue 21 Jun 22 @ 2:25 pm
