Running latest version of VDJ on Win 10. Even with the Browser set as writehistory = Yes, VDJ does not make an entry under History. It started doing this a few months ago.
How do I fix this? Thanks in advance for any help. :-)
geposted Tue 31 May 22 @ 3:38 pm
What is your historyDelay setting?
You also need to have the audio playing to record history (i.e. faders up and not just PFL)
geposted Tue 31 May 22 @ 4:24 pm
+1 for checking your HistoryDelay setting.
Also, this is a longshot, but check to make sure the History folder in your Documents\VirtualDJ folder has write permissions.
geposted Tue 31 May 22 @ 8:15 pm
And setting "writeHistory" is set to yes..
geposted Tue 31 May 22 @ 8:18 pm
