A suggestion for those brilliant Virtual DJ developers:
Could you consider making the button editor top action coding pane taller.
I believe it's higher priority for more space in the coding than category/desciption/properties lower panes.
It doesn't save the enlarged state but even with it stretched vertically to the maximum, it seems to divide the size in half between the upper and lower panes. I believe the upper coding pane is priority to see all the code as it's being edited.
Thanks!
Thanks!
geposted Mon 06 Jun 22 @ 3:25 pm
