Topic: HELP : Pioneer DDJ-SB not detected...
Hi everyone,
I have a controller Pioneer DDJ-SB, and a Mac. I bought the PRO Virtual DJ License and my controller is not detected by Virtual DJ and I don't know why...
In the AUDIO menu, my controller is appearing, but when I go into the MAPPING menu, my controller is not there. I only have the choice between Keyboard, Midi USB or the controllers list.....
Can anyone help me with that ? I'm very disappointed because I juste spent almost 20$ today for Virtual DJ and I can't use my controller !
Thank you for your help,
Hugues
geposted Sun 12 Jun 22 @ 2:57 pm
Any other Application running at the same time that could take over the device ?
What is "Midi USB" ? Is it some other MIDI device you have connected ? Have you tried without it ?
See what devices are detected by your OS in Utilities->Audio MIDI Setup ->View -> MIDI Studio
Also try to disable IAC Driver (if enabled)
geposted Sun 12 Jun 22 @ 6:06 pm
I’m soo disappointed I just payed 20$ and my controller is not found in the virtual dj pro. Anybody can help?
geposted Sat 04 Feb 23 @ 4:50 am
Please make sure that you have the last firmware and driver installed, reboot the system and try again.
You can find them here:
https://www.pioneerdj.com/en-us/support/software/ddj-sb/
geposted Sat 04 Feb 23 @ 9:43 pm
