When starting b6978 I see a 'downloading...' message in the status box in the browser, but, for less than a second.
My Mac is boot camped with Windows 10 and the PC version updated to b7009 with no trouble.
Years ago I remember there was a hidden cache that sometimes needed to be cleared to enable the download, but, can't remember the details.
System Specs;
MacBook Pro 15” 2017 (Touch Bar), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Monterey 12.4, 500gb SSD Bootcamped with Windows 10 x64bit. External WD Passport Ultra 2Tb HD containing Music & Video databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2021 b6978 and Controllers - Denon MC7000, Denon MC6000 MkII.
System Specs;
geposted Fri 17 Jun 22 @ 3:03 pm
Me too. Please correct the permissions of the update-link.
<?xml version="1.0" encoding="UTF-8"?>
<Error><Code>AccessDenied</Code><Message>Access Denied</Message><RequestId>9FVK7T5EB90D6026</RequestId><HostId>LxuOL5TBv4e0uJIIo5RKZ29+W3F8iQEflJ206pWswRL62yQPiTAqiEkwIBaGVirr3PCXng6VxZI=</HostId></Error>
geposted Fri 17 Jun 22 @ 4:03 pm
Why don't you guys just download b7009 directly from here, if the update doesn't work?
geposted Fri 17 Jun 22 @ 4:54 pm
Update of Early Access should be good now on Mac.
geposted Fri 17 Jun 22 @ 5:26 pm
Tried that earlier today Groovin and was unsuccessful.
Have just managed to get 2014 down manually and installed.
Cheers
Les
geposted Fri 17 Jun 22 @ 7:55 pm
