It just sucks with vdj. Looping is horrible, sound effects from the controller are meh. The autogain on this unit working with vdj is horrid. I want to try it with rekordbox and see the difference.
geposted Tue 21 Jun 22 @ 1:04 am
That's strange, I've seen a few FB posts on how great the integration is with the DDJ-800, and it would be on my short list of great controllers to use with VDJ
A couple of things:
1. The effects are going to be the VDJ effects - you can change them around and add new ones, and remap which ones to use with the controller, but the DDJ--800 doesn't have hardware effects
2. The looping should be just like clicking the loop section on the screen (or the pads when loop is selected as pad page). If it is indeed the same, and you don't feel like it acting like you want it to, you could look into some of the auto/quantize settings in case it's not set up how you like. There is also the reverse vs forward loop setting to look at
3. There is no autogain on the controller. It's all VDJ (and the controller just send midi messages when you turn the gain knob). If you want to learn more on how autoGain works in VDJ the video below may inspire you:
A couple of things:
geposted Tue 21 Jun 22 @ 9:39 am
I'm spoiled. I have a ddj-rz/sz and its set to external hardware and it sounds fantastic. I dont have turn a volume knob up/down after loading a track to equalize anything. Just solid perfect djing with no worries that the next track IF I TOUCHED the gain knob will be too quiet or too loud. I lament any and all controllers that rely on the software to control all aspects of your sound.
I must be getting cranky in my old age
geposted Sat 08 Oct 22 @ 10:09 pm
