one key copies the track from 1 to 2. The other key copies from 2 to 1. Regardless of which wheel is playing or the hand is touching.
geposted Tue 28 Jun 22 @ 4:46 am
clone_deck
geposted Tue 28 Jun 22 @ 5:04 am
clone_deck or clone_from_deck - it depends of which wheel is playing or the hand is touching.
geposted Tue 28 Jun 22 @ 5:44 am
As with all scripts, you can add the deck
deck 1 clone_deck
deck 1 clone_deck
geposted Tue 28 Jun 22 @ 5:52 am
ADION
great, thanks
great, thanks
geposted Tue 28 Jun 22 @ 5:56 am
