Topic: Mixars Quattro color FX
I have a very strange issue with a Mixars Quattro.
Channel 2 is playing, and I activate the filter color fx using the button on the mixer. When I then turn channel 2’s filter knob nothing happens, but channel 1’s filter knob applies filter to channel 2 (and also channel 1)
I am fully aware the the color fx on this mixer is hardware based, but when I try with Serato everything works as expected..?! Also when playing analog, the color fx work as expected.
I am running with factory default mapping, and I can see in the mapping dialog that the the Quattro sends midi for the filter knob when a color fx is active, but not when no fx is active.
Since it works as expected with Serato, VDJ must do something differently that triggers this issue.
Edit:
Intel Mac
MacOS Monterey
VDJ build 6878
geposted Tue 28 Jun 22 @ 4:01 pm
You need to use the correct audio setup for your controller which in this case is this:
My issue was that the “Speaker+Headphone” was also selected. I am not sure how that happened, but I may have messed up.. 😬 Or maybe messing around with different controllers/mixers left it in that state.
With only “Mixars Quattro” selected, it works correctly. 👍🏻
Thanks Phantom!
