Hi,
is there a way to ask the loaded track has cue_action?
I need this for:
this doesen't work
i testet many but i doesen't found the right way.
And the second Question.
Can i create a Button in the Skin XML wit cue_action?
With " " the Skin crash and with ' ' it doesen't work
I need this for:
<panel visible="cue_action 2 ? on : off" >
this doesen't work
action="cue_action 2 var_equal '@%cueaction20' 1 ? goto_cue 3 : nothing"
geposted Tue 05 Jul 22 @ 3:24 pm
For second question:
the action needs to be in quotes.
or
should work in your skin coding. (not tested the 2nd)
action="cue_action 2 `var_equal '@%cueaction20' 1 ? goto_cue 3 : nothing`"
or
action="cue_action 2 'var_equal '@%cueaction20' 1 ? goto_cue 3 : nothing'"
geposted Tue 05 Jul 22 @ 6:00 pm
Thanks for your awnser.
The fist one with the `` works. But only when a CUE 2 is set before.
The second with the & a p o s ; doesn't work.
This script do what i will:
Now i need a tip for the fist question.
action="set_cue 2 & cue_action 2 `var_equal '@%cueaction20' 1 ? goto_cue 3 : nothing`"
geposted Tue 05 Jul 22 @ 8:54 pm
Yes need to create the cue first before setting an action for it.
and maybe of interest:
and you may already be aware of, one can set name and color of cue within the button. cue_name and cue_color
(currently cannot change/set, cue Type (accept for Action) or the invisible/'marker only', attributes)
and can query if cue 2 exists, and do different things depending on outcome. has_cue 2
and interested in answer to first question. ie can the cue_action verb be queried.
geposted Tue 05 Jul 22 @ 9:50 pm
