Topic: Script Help? Help me Script a button
My Goal is to set a button FX_TAP on the RANE ONE To do as follows...
Goal:
On 1st Tap Do all this
-Disable Crossfader
-Disable Master Tempo
-Set X-Fader Curve to Scratch
-Set Pitch to 50%
-Blink (While Active)
-Load Scratch Bank (which is located on Pad bank 4 menu 2 - Pressed twice)
CURRENT SCRIPT IS: Is this correct as It seems to work at the moment only for 1st Tap.
crossfader_disable & master_tempo & crossfader_curve "scratch" ?blink 1000ms
Tap Again: Turn all Goal 1 off, but also
-Enable Crossfader
-Enable Master Tempo
-Set X-Fader Curve back to last setting
-Set Pitch to 100%
-Unload Scratch Bank & Return to Hot Cue Pad Bank (Bank 1)
geposted Wed 13 Jul 22 @ 5:38 pm
