Hey all, have a very strange issue happening with shaders on my new macbook. No matter which one I select the beatmove feature no longer works.
I'm running OSX Monterey (12.5) and VDJ 8.5-arm b7032.
I've tried:
-removing and reinstalling the shaders
-removing and reinstalling VDJ
-Testing the shaders on my previous Macbook (working with no issues) and PC (working with no issues)
-Testing the "useLowPowerGPU" option both "Yes" and "No"
Is anyone else experiencing anything similar or found a solution?
I've tried:
geposted Sat 23 Jul 22 @ 5:20 pm
I have a Macbook Pro15 2018 6 core Intel 7
macOS Monterey 12.4
VDJ 8.5 7032
BeatMove Works for me
Do you have M1 or M2 processor?
macOS Monterey 12.4
VDJ 8.5 7032
geposted Sat 23 Jul 22 @ 6:11 pm
Its an M1 Processor.
Like I said above I tested it on another macbook (2015, running Monterey) and its fine.
Its just my new one that it does not work on.
geposted Sat 23 Jul 22 @ 8:12 pm
As an update: contacted support and was told to try deleting the settings file and reinstall the software. Other than that "there is no current solution to this problem"
With that, I also tried deleting the plugins folder as this contained the shaders and manually re-installing them.
Still does not work.
geposted Wed 27 Jul 22 @ 11:31 pm
Issue has been fixed with latest update (8.5-arm b7059)
geposted Wed 10 Aug 22 @ 8:44 pm
