Is there a skin for this or just use something similar?
I know that some think the skin isn't that important since you're using the controller but sometimes it helps having the same skin as what you're using in case you run into any unexpected button or knob changes right before a gig and you're trying to figure out what's going on.
You may think your speakers are blown when all it was the filter knobs had been turned just a little bit during transport to your event.
I've gotten better about checking everything but I was just curious especially since these controllers are newer and I see some really old Numark skins on here.
geposted Sat 23 Jul 22 @ 5:49 pm
No, lookey-likey skins are not a thing any more.
It doesn't seem to be an issue for users of Serato, Traktor, Rekorbox etc.
geposted Sat 23 Jul 22 @ 10:52 pm
