I'm not sure what happened because this wasn't the case a couple days ago but the effects sliders on both decks have the same name now so I can only map knobs to deck 1. When I use the eye dropper to map they are both called "effects slider 1" instead of "1 2 and 2 2" like they used to be. When I click the right deck to map it maps my knob to the left and doesn't move the right
I was using a Traktor Kontrol S2 before and the names were different, i could map each deck's sliders to different knobs. That controller died so I hooked up an old Hercules Dj Control Air and a Traktor Kontrol X1 just to map the effects since I don't have the knobs for them on my controller. Even with JUST the X1 or nothing plugged in both decks have the same name on all of the effects sliders. Everything else seems to be working like it should
Is there some setting I'm missing or a way to edit the names of the effects sliders to have them separated again?
geposted Sun 31 Jul 22 @ 8:04 pm
