Topic: Echo effect and volume fader
Hi,
Pioneer DDJ-SR2 and echo effect. I have seen with some other decks and software that when the echo effect is activated and the volume fader slammed down to 0, the effect continues as a way to transition into other songs. However, with virtual DJ when the effect is active and volume fader slammed down to 0, the volume cuts out. Is there a way to have the effect continue few a seconds when the volume fader is slammed down to 0?
geposted Sat 06 Aug 22 @ 11:27 pm
Yes, if VDJ is handling the mixing there is (if the audio config is set to use external mixer, then this physical mixer will of course turn down everything- nothing VDJ can do about that)
Anyway, it's called post-fader fx so try looking up fx-processing in the VDJ settings
As an alternative there is also a special echo effect that you can arm and then use, that does exactly what you describe. More info here;
Finally you can also use the echo sound color fx to do something similar to what you want - so there are really a lot of options :)
For post-fader Effects, you need to set fxProcessing setting to Post-fader
Best not to slam faders either, as you'll probably end up breaking something.
Hi All,
Just wanted to say a huge thank you for all your suggestions and support. This has helped immensely and is really appreciated.
Changing the fx processing option to post fader has worked a treat. Last question, what settings should are recommended for the echo effect in terms of beat, frequency etc...
