When the fader is turned off, I want to listen to the sound in the headphones so that the crossfader can check the scratch in the headphones.
geposted Fri 12 Aug 22 @ 1:19 am
It's correct because it's PFL
geposted Fri 12 Aug 22 @ 7:14 am
how then to configure
geposted Fri 12 Aug 22 @ 1:03 pm
You can't. It is what it is. In my 40 years as DJ I have never worked with one with AFL so I think 99% off all mixers are made like that.
geposted Fri 12 Aug 22 @ 2:52 pm
Many mixers offer a knob to choose between hearing PFL and master in the headphones.
Within VDJ this is also available on the mixer tab (called "MIX")
geposted Fri 12 Aug 22 @ 3:52 pm
ADION
you still can't doing the scratch in the headphones if the channel fader is turned off. Sound does not respond to the crossfader
geposted Sat 13 Aug 22 @ 1:57 am
Sandbox
geposted Sat 13 Aug 22 @ 8:06 am
please add a setting for crossfader
geposted Mon 15 Aug 22 @ 6:21 am
