Hey y'all,
How do you define which deck you want to be selected for a keyboard/midi input? Right now I've tried mapping an input to select a specific deck, e.g. "Deck A."
However, instead of selecting just that deck, it seems to cycle through decks a, b, c, d, and in that order. Is there a way to ensure the "select deck" command selects a specifically defined deck rather than cycling through them? Is there a different term I should be using for "deck a?" Or am I misinterpreting the "select deck" command? I want to also map certain commands to whichever deck is selected. Right now, the script I'm using is simply:
See this video here where I recorded my UI: https://youtu.be/ek5hrEaqgD8
As an aside, I'm trying to select "Deck A" but it just cycles through all decks. I've also tried mapping pfl to "deck active" and it only does it for Deck A regardless of which deck appears to be selected.
select Deck Aor
select Deck Bfor a different keyboard input.
geposted Mon 15 Aug 22 @ 8:13 am
The "select" script does not take any parameters.
In vdjscript, the deck a script applies to comes before the script itself.
So to select deck 1, you can do
deck 1 select
geposted Mon 15 Aug 22 @ 11:53 am
deck 1 select
Thank you! This works!
geposted Fri 19 Aug 22 @ 11:39 pm
