I'm using VDJ2021. Is it possible to change the highlight colour in my browser. I need it to be brighter than it is. Am I right to assume that Browser Tweaks does not work with this version of VDJ?
geposted Mon 15 Aug 22 @ 1:10 pm
Can be done with Browser Tweaks, but needs a zip file, so u need a few steps to follow to edit the default skin as it's integrated in the software
Open VDJ, select the "Default" skin from Settings->Interface tab and then "Edit this skin" from the right side.
Open the /VirtualDJ/Skins/Default folder , zip all files, name the zip as e.g. "MyDefault", then put the zip file to /Skins folder.
Open Browser Tweaks, select the "MyDefault" skin and simply change the Focus color in Lists tab
geposted Mon 15 Aug 22 @ 1:52 pm
where do i get browser tweaks from?
geposted Wed 31 Aug 22 @ 1:18 pm
geposted Wed 31 Aug 22 @ 1:34 pm
