Topic: Map Pads / Sample Mode
Hi I wonder if anyone can help me, I have just bought a Numark Mixtrack Platinums FX controller, I would like to be able to map the 8 performance pads in sample mode to play drops from a folder I created in samples called "DJ Drops" can anyone help me please with the mapping code TIA
Yes I am a home user so the controller only works for 20 minutes or so if I can get it to work I will buy a Home Plus license.
geposted Fri 19 Aug 22 @ 8:53 pm
You don't need to map the pads. You just need to add your samples to sample slots in VDJ. Details in the VDJ manual.
geposted Sat 20 Aug 22 @ 3:52 pm
