Topic: Headphone Volume Controller issues
Lately my headphone volume resets to zero(no sound) whenever i restart VDJ or when i change a setting to my skin. it happens with my sx3 but not with my ns7iii
anyone with a solution?
this never happened before
thanks
geposted Sat 20 Aug 22 @ 4:43 pm
I don't have a solution but I'm facing the same Problem.
That just costed me about an hour to figure out why my headphone is not working while I was setting up my new laptop.
I did not have the master volume view open, so I did not see the headphone volume being all the way to zero.
Also it resets the balance between master audio and pfl audio.
I don't use these controls normally, because I have the same built in as hardware on my Denon MC6000MK2. I just want a dry pfl signal on full volume and I don't want to set them on every VDJ Startup.
I assume this is some kind of bug, that should be fixed immediatley.
Which skin are you guys using?
Adion just mentioned elsewhere that Controller 2020 by DennYo is changing the settings.
This is a BUG in my skin. The next Update doesn’t change the Headphones. It is uploaded and waiting of review from Atomix.
