Version: V8.5-64 b7082.
I don't know if the problem is local to me or a bug. Here is the description:
If I click on my standard playlist folder under "Lists & Advice"
and then create a favorites folder via the left star button "Add Favorite Folder",
There are some, but not all, subfolders that are missing the triangle or (depending on the skin) the +-sign in front of the label.
Can someone reproduce or verify this?
geposted Mon 22 Aug 22 @ 12:48 pm
A week later. Just not to be forgotten. ;-)
Can someone adjust or prove that if necessary.
Just to see if the problem is unique to me.
Thanks in advance
Thanks in advance
geposted Mon 29 Aug 22 @ 3:21 pm
Since no one has been able to test it so far, I installed a new virtualdj on a test system.
Here I have created 3 subfolders (subfolder 1,2,3) each with a few playlists in them.
Alsa a playlist in the root folder (playlist222).
Here you can see the + signs in front of the subfolders.
Then I created a favorite folder from this "Lists & Advice" from "Playlists".
Here you can see the bug: Only the subfolder2 has a + sign at the front.
Subfolders 1 and 3 are missing the + characters. This is the bug ;-)
Hence the small problem: if you have a lot of playlists or subfolders, then you can not quickly recognize the subfolders in the favorite folder of the playlists.
see photo...
see photo...
geposted Thu 01 Sep 22 @ 9:41 am
