Hey guys, my bud was playing tunes for a little while in Automix mode then when I took over I am seeing like the tune's album cover in the Automix pane, please see attached image and tell me how I can get out of that mode and get back to the Automix pane?
https://i.postimg.cc/R0QpmyhV/Screen-Shot-2022-08-23-at-9-18-48-AM.png
geposted Tue 23 Aug 22 @ 1:28 pm
click or drag the tabs just below your arrow
geposted Tue 23 Aug 22 @ 2:00 pm
Geez, so simple, I spent a lot of time trying to get back the automix pane, thank you!!
Next, when playing with both decks in normal mode [with Automix turned off], the pitch control in both decks are moving on their own whenever I load songs into them, how/where can I disable this setting please? I have looked at all options in Settings but not noticing anything for this specifically?
geposted Tue 23 Aug 22 @ 2:17 pm
Check settings for BPM match, auto pitch etc. under automation settings like the following
autoBPMMatch
autoPitchLock
autoBPMMatch
autoPitchLock
geposted Tue 23 Aug 22 @ 3:43 pm
Yes, under automation looking in Automation settings please see the default settings attached then my unchecking any "auto" or Smart options and yet no change.
https://i.postimg.cc/vTTVY60P/IMG-3805.jpg
https://i.postimg.cc/x1Mb1QPS/IMG-3806.jpg
geposted Tue 23 Aug 22 @ 4:13 pm
it's ok guys, this is now solved, I got the help from VDJ Support, seems I had to deselect the Autobpm option in "Deck options" in each deck's pane and not in Settings Panel.
geposted Tue 23 Aug 22 @ 10:23 pm
Having the same issue, but it's slightly different...
https://i.postimg.cc/QNRsTLY2/image-2024-10-07-202339173.png
geposted Tue 08 Oct 24 @ 12:22 am
click on the folders Button or drag the vertical folders line to the right
geposted Tue 08 Oct 24 @ 9:06 am
