Topic: Error on the platters. Using Numark MixTrack Platinum.
Just a heads up. I'm using the latest build 7093.
I don't mind the error but it would be nice if things ran like they should.
I don't want to use a previous build being that i use stems.
geposted Tue 23 Aug 22 @ 7:15 pm
Any chance you have a force- file in /devices folder ? If so, delete it and restart VDJ
geposted Tue 23 Aug 22 @ 9:43 pm
YOU are a genius my man. I just deleted that file, restarted VDJ and presto no more errors. Thank you!!!
geposted Tue 23 Aug 22 @ 9:48 pm
Okay, so this is follow up to my previous question/comment. I deleted the files in the device folder to eliminate the errors on the platters but now I'm getting that dreaded Mixtrack Platinum humm. I had to re-install the Numark Mixtrack Platinum fix extension to remove the humming noise but now the errors are back. Any advice?
geposted Wed 24 Aug 22 @ 8:28 pm
