Topic: Virtual Folder vs Playlist
Is there an easy way to convert virtual folders to playlists?
geposted Wed 24 Aug 22 @ 12:33 pm
There are a couple of ways I know.
1.Right click on the virtual folder and select "export" then "save as a playlist" in the folder "Documents/VirtualDJ/Playlists".
2.Best is to right click on the virtual folder, select the contents using Ctrl A and then load to automix. Next click on the automix radio button and then select "save as playlist".
It would be good if there was a simple right click option in the virtual folder context menu?
You might already be doing one of the above.
I'm going stupid. its old age. In the 2nd method just right click on the virtual folder and load in automix. Then save as a playlist.
I am in my 70s LOL.
Bye.
