Like the title says in VDJ I suddenly do not have access to all of my shaders. I looked in Plugins/Visualisations within the main VDJ directory and do see them there. Any help or advice would be appreciated so I can get them back into the mix.
geposted Thu 25 Aug 22 @ 10:15 pm
Are you on the latest Early Access build?
Because that has a few changes to shaders, so I guess that could be a reason for it
If you are on the latest public build or anything older than that, then that is probably not the reason
geposted Fri 26 Aug 22 @ 6:10 am
Also, depending on your computer and the version of VDJ you are running, you may need to look in Plugins64 or PluginsArm instead of Plugins
geposted Fri 26 Aug 22 @ 6:24 am
I appreciate everyones replies. I am using the current version (public) so I am not sure what happened. I just spent the past few hours downloading them again so I am good for the weekends shows.
Thanks
Rich
Thanks
Rich
geposted Fri 26 Aug 22 @ 7:11 am
In the future if you need a collection of shaders, you can get them pre-downloaded and pre-compiled here:
https://www.youtube.com/watch?v=4Ok65rxyMR0
If you are on windows they can also be pre-grouped
geposted Fri 26 Aug 22 @ 9:54 am
