When I go to the left or right with the crossfader, nothing happens. The sound is full on both channels.
The sound faders work, but the crossfader isn't assigning the decks to one side or the other.
geposted Fri 26 Aug 22 @ 2:08 pm
Maybe just needs reseated.
geposted Fri 26 Aug 22 @ 2:31 pm
To troubleshoot the issue:
1) When looking at the Mapping interface in VDJ, does the crossfader output values from 0.00 (Left) to 1.00 (Right) ? (and Mapping: CROSSFADER, w action of "crossfader") If so does the software crossfader then move correctly as one moves the crossfader on the MC7000.
2) Are the 4 crossfader "assign" switches (above each of the volume faders) in the correct positions? IE are the 4 switches NOT in their center position, (the Thru, position) and does the software show the expected crossfader assigns? (use the crossfader menu dot to hide or display crossfader assigns in software)
![](/img/364181/74865/Crossfader Assign2.png)
If the crossfader is outputing expected values with its movement, and the software has the crossfader assigns correct, then it should work.
geposted Fri 26 Aug 22 @ 2:34 pm
Just fixed it, yes the fader was assigned to THRU, instead of A on left, and B on right.
I replaced the fader, and didn't realize the settings had been changed. Thank you for the HELP!
geposted Fri 26 Aug 22 @ 2:40 pm
Awesome :) Gotta Love the MC7000 !
Curious was the replacement easy to do, and what did you choose for the replacement.
Wanted to learn, from your experience, for when I may need to do the same.
geposted Fri 26 Aug 22 @ 2:45 pm
