I use this script on padpages since many years:
Pad 1 : saved_loop 1 ? saved_loop_prepare 1 : loop ? saved_loop 1 & loop_color 1 'yellow' : nothing
Pad 2 : saved_loop 2 ? saved_loop_prepare 2 : loop ? saved_loop 2 & loop_color 2 'yellow' : nothing
Pad 3 : saved_loop 3 ? saved_loop_prepare 3 : loop ? saved_loop 3 & loop_color 3 'yellow' : nothing
Pad 4 : saved_loop 4 ? saved_loop_prepare 4 : loop ? saved_loop 4 & loop_color 4 'yellow' : nothing
But for a while now, only loop1 is saved in yellow, loops 2,3 and 4 are saved in white....
Is there anything wrong with my script? But before 2 or 3 month, it worked fine, all loops was saved in yellow.
I run on V8.5-64 b7093, original pro license.
It's not very important, just a small point, thanks for your help.
Best regards.
Best regards.
geposted Mon 29 Aug 22 @ 6:37 pm
The problem is fixed: the loops are saved again by default in yellow. I didn't change anything, but maybe an update fixed my problem... :)
geposted Wed 16 Nov 22 @ 1:36 pm
