HI, does someone is able to tell me a string to assign the "pitch bend" function to a knob on my AKAI AMX controller? It is for default set for "beatjump". It would be more useful as a pitch bend. I'm just looking for the correct command string to input then I'll select the correct knob to set. Thanks in advance to those who answer me.
geposted Thu 01 Sep 22 @ 1:59 pm
