Topic: play list issues
This seems to be a bug or settings issue ill try to explain best i can and i would like someone to explain why it does this and how to fix it.
At home i make playlists and save them to a folder on my external drive that my tunes are on, at the club i plug in my drive and everything shows up, thats in the front room.
However in the back room i plug in my drive and while the playlist folder shows up it acts like its empty, what makes this odd to me both club comps run win 10 and the lastest vdj, why do my drive playlists show on one comp and not the other.
How do i fix this annoying issue?
Many thanks for cluing me in.
geposted Tue 06 Sep 22 @ 10:32 pm
More likely a settings issue.
So basically, check that these settings are the same among the 2 PCs:
1) showM3UAsFolders
2) showMusic
3) showVideo
4) showKaraoke
Thanx i will check that friday, the patio comp is the one with the issue and lots of cooks in that kitchen each one sets things to their liking not always the corrrct settings.
Yep, that was the setting many thanx!
