Hello
Do skins exist that allow me to select more than 8 saved loops? E.g. a "browsing capability" so i can go to the next 8 saved loops and so on, would be perfect for me. Or is there a way i can program a shortcut for that myself ?
Many thanks
Many thanks
geposted Sun 11 Sep 22 @ 9:57 am
The easiest way would be a custom pad page.
Take a look at this page as an example:
https://www.virtualdj.com/plugins/index.html?addonid=81517
This pad page extends the hotcues (not the saved loops) that you can access through pads up to 112
You can create something similar, or even mod the above page to also support saved loops.
geposted Tue 20 Sep 22 @ 11:52 am
