Forum: VirtualDJ Skins
Topic: Default Pro skin help
Hey guys can anyone help i need someone to edit the skin where I can have 8 samples on the left deck and 8 samples on the right deck instead of them being 16 just on the right handside, if someone could help that would be great..
Cheers
Wazza
geposted Sun 18 Sep 22 @ 1:58 am
Cheers
Wazza
The easiest is simply by putting all 16 samples in the sample sample bank.
When VDJ "runs out of sample pads" it starts using both decks to get more room
geposted Sun 18 Sep 22 @ 5:46 am
Yes easy, and this works perfectly if you have only 2 sample banks. (16 total samples)
For more then 2 sample banks this method could become unwieldy, as it would difficult to have sample bank 1 and sample bank 21 as Left and Right Sample banks, and then quickly change the left sample bank to, sample bank 7 and still keep the right deck's sample bank at sample bank 21 .
A solution would be for VDJ to have a 2nd sample bank that could be displayed simultaneously.
This would allow VDJ to have 2 independent samplers. One could be used for left and 2nd for the right deck.
See wish for this feature to be added:
http://www.virtualdj.com/forums/247590/Wishes_and_new_features/Wish_for_2nd_Sample_Bank___(to_be_displayed_simultaneously).html
And you may find this recent related thread of help:
http://www.virtualdj.com/forums/247643/VirtualDJ_Technical_Support/More_than_8_samples_breaks_controller_pad_use_.html
geposted Sun 18 Sep 22 @ 9:59 am
