Forum: VirtualDJ Skins
Topic: Videoskin for mac & pc
WahlossPRO InfinityMember since 2017
Will a videoskin created for pc also work on a mac or are they differences in the script?
If so, what are the differences?
geposted Thu 22 Sep 22 @ 12:08 pm
No they're universal
geposted Thu 22 Sep 22 @ 12:15 pm
Great! Thanks!
geposted Thu 22 Sep 22 @ 12:17 pm
There's a minor difference on how text appears between the two OS.
Therefore, depending on what elements you put on a videoskin, you may want to also preview it on both systems before finalizing it.
Differences are not major, but if you try to squeeze a lot of text in small areas, you may need to adjust things a little bit.
geposted Mon 26 Sep 22 @ 11:55 am
I assume you can add different text code for each OS and have the videoskin check, the same as with normal skins?
geposted Mon 26 Sep 22 @ 4:48 pm
Just making sure the text areas have a couple of pixels extra space should be fine
geposted Mon 26 Sep 22 @ 6:06 pm
As Adion said, just make sure you don't squeeze the text without any "headroom" pixels.. :P
Other than that, yes you can make the skin check the OS and use other text in case of each OS, but I think there's no need for that unless you want to use some kind of font(s) that are not available on both platforms.
So, if you want to use some special (different) font(s) then yes you'll have to make the skin query the OS that's running.
geposted Mon 26 Sep 22 @ 10:02 pm
