Topic: DDJ REV 7 Effects
MHand7PRO SubscriberMember since 2016
I'm about to pull the trigger and purchase a Rev 7 but I have a question
The manual says you have to choose hardware or software effects for the paddles. Is it possible to use the hardware effects on the paddles but still have software effects on some of the pads for a pad FX setup??
Also, does the smooth echo-out button work with VDJ?
Thanks
geposted Fri 23 Sep 22 @ 1:37 pm
Yes on both questions.
geposted Mon 26 Sep 22 @ 10:55 am
