Hi,
when i use the Custom Browser Element <filelist source="sidelist"> there is no Index on the Top? I think it's a Bug.
On <filelist source="automix"> is the Index visible.
SIDELIST:
AUTOMIX:
SIDELIST:
AUTOMIX:
geposted Tue 27 Sep 22 @ 10:19 am
It's because the sidelist as a separate list is by default used below the main list.
Will add so that you can force it by adding headerheight="1" in the next update.
geposted Tue 27 Sep 22 @ 12:05 pm
Thanks for this Info :)
geposted Tue 27 Sep 22 @ 5:34 pm
Thank you it works with the newest early Access.
geposted Mon 10 Oct 22 @ 1:04 pm
Query on this, I have
<filelist [no source] as main files [needed because of custom toolbar]
and
<filelist source="sidelist" headerheight="1" as a standalone sidelist [sideview is doing something else]
problem is these lists the headers are linked but separate would be better,
anything I could add to setting browserColumns? or am I out of luck?
and
geposted Mon 24 Oct 22 @ 12:34 pm
I changed the source to karaoke as a work around to get independent headers.
geposted Mon 24 Oct 22 @ 6:32 pm
