Good day,
If I use the script under the button
effect_select 'colorfx'
The colorFX effects popup will appear.
If I use the same script for the knob, the colorFX effect automatically changes according to the knob settings.
This is clear because the value of the knob setting is passed directly to the expression.
How can I make a popup window appear when I use the knob?
geposted Mon 03 Oct 22 @ 9:24 am
