Hey guys,
I am trying to get my cue to play while using virtual DJ with Pioneer XDJ RX2.
I've installed the necessary drivers and have no problem with all other features, however I can't get the cue to work. I've tried changing the audio options in virtual DJ and on my software and still no luck
Any advice is welcomed and greatly appreciated
geposted Mon 03 Oct 22 @ 10:46 am
I have the RX2 also and it works fine for me on both my laptops.
You dont mention whether this has ever worked previously before, or if this is the first time you are trying to use it.
Firstly, it would be a good idea to post your audio config in VDJ with the RX2 connected to understand where the problem may be.
Secondly, it's worth plugging a USB key and seeing if the cue function works full stop.
Lastly do you use the RX2 in internal mode or hardware mode? As that makes a difference to how the audio config should be setup. Take a look here for more help - https://www.virtualdj.com/manuals/hardware/pioneer/xdjrx2.html
geposted Mon 03 Oct 22 @ 11:32 am
